cpu temps after new build, help?
1 Apr 2007
hi,
im running an asus p5b, e6600 with tuniq 120...
seeing as the asus packaged software doesnt come with anything that will run on vista 64 bit, ive just downloaded speedfan to see what my temps etc are whilst running in vista.
here are the results:
system 25
cpu 35
aux 127????? what is aux???
core 0 = 22
core 1 = 22
is there a better program to use than this? im abit sceptical about it seeing as in the bios it says my cpu temp is around 38 and system is more like 28
thanks
Intel TAT is really the most accurate CPU temp monitor for c2d processors...I use everest which reads a few C lower than the intel TAT but I prefer it as I can display it on my keyboard lcd.
Think you need to right click the icon , properties and click run as administrator of something similar (few months since i was last on vista), ill try and find a definate solution tho.
EDIT: Had quick look, its: Just right click on TAT icon -->properties-->compatibility--> check on run as administator.
