Afternoon all.
Currently running a 1st gen ryzen 1700 and wondering if a jump to a 5600x or a 5800x would be worth doing at my resolution.
Usage is very much aimed at gaming, and at 1440p I'm.not sure how much of a boost I'd get over the 1700.
During any games the gpu, 3080fe, often its at low utilisation, 60-80% I'd say on average so I'm thinking the cpu is holding it back somewhat.
I know there is the imminent release of the 5800x3d but its highly likely that will be prices above the current 5800x's £299 so I don't think for my use case iflt would be worth it.
I've considered the 12600k and a B660 as it comes in at very similar prices but I'd then also need to sort a cooler bracket and by the sounds of it move to windows 11.
Any thoughts from anyone who has made a similar move?
. As long as you're keeping it under 90c then I wouldn't be duly concerned.
