- 23 Nov 2018
Current system is running with;
Motherboard: Asus Sabertooth Z77
CPU: Intel i5 2550K
Ram: 16GB DDR3
I want to upgrade my CPU ideally to 8th/9th gen (bit more research still to be done hence this post.) To upgrade from my current CPU I will need to buy a new Motherboard and RAM.
Trying to explore all options at the moment, with an emphasis on "best bang for buck" or is there a good middle ground option i.e. 5th/7th gen?
Alternatively I use AMD rx570 GPU so would a Ryzen build be a good option with an AMD GPU?
CPU: Intel i5 2550K
Ram: 16GB DDR3
