CPU upgrade or nah?
3 Jan 2012
Lancs
Currently got a 5800X on an MSI b450m Mortar Max with a an XFX 6700X GPU.
Was wondering if trading in the 5800X and switching to an X3D model 5600/700/800 would be a worthwhile change or not.
TIA
What do you use the PC for? What resolution do you play at?
Are you on a budget?
I have a 5700X not the 3D with a 7900XTX at 4K and I weighed up the option of going to a 3D but figured I'd save the money until I do a full upgrade at AM6. So it might not be worth it, you could look into a new gfx card? As it'll be fine to carry that over if you ever end up upgrading the rest?
Realistically, unless you're noticing the 1% lows you wont notice any difference with an X3D chip of the same generation.
