CPU usage and RAM usage going nuts (vista 64)
19 Oct 2002
Torbay, Devon, UK
I have done a fresh install a couple of days ago. And all have been going fine.
About an hour or so ago, my CPU was sitting about 53% and about 6 gig was being used.
Task manager under processes was not showing anything using that amount.
Any one have any clues.
Its gona back to normal now. Ran a virus check to make sure NOD says Im free.
I have been running vista 64 since launch and never had this.
But I will remember it if it happens again.
i had this happen once before was itunes.. it said t was using 100MB ram but when i closed it 99% ram usage went to 10% 5.8GB usage to 1.3GB
I had to do a fresh install of vista due to it breaking.
I have steam installed but not loaded, and windows has gone nuts again.
Now here is a strange one. When my pc goes nuts, my wifes lappy loses net connection.
Im wired to the router she is wireless.
I never had any problems before I swapped from my abit IP35 Pro.
Edit
Could the LAN cause this. (may try my usb wireless to see if it is)
