Commando CPU Vcore 1.65. Problem - SOLVED!
I am setting up my first water cooled rig and went straight for 3.6GHz with my E6600 (400x9). At the moment I have Vcore set in the BIOS at 1.65v, RAM at 2.1v (800MHZ 1:1) and NB Voltage at 1.4 and eveything seems stable with Prime95. Lowering the CPU Vcore will cause Vista to crash or not load. Temps using Intel TATS is 35 idle and 70 at 100% on both cores.
So to me the max temps seem well with limits (but why the big variation between max load and idle?) and the rig seems stable. So am I going to do any harm running at 1.65v (most people I see are runing 1.4-1.45v). Only ever played with AMD CPU's before so some of this is new to me.
BTW whats VID in Core Temp Beta0.94? It reports 1.325v and Voltage on CPUZ is showing 1.056v?
Cheers
Cheers
Now you should try for 3.8ghz. You have some headroom on your vcore, and there's no point in watercooling if you're not going to push it
