Can coretemp reported vids on Q6600 chips differ from motherboard to motherboard? A while back I tried a Q6600 on an Nvidia based board and then an Intel one and the VID stayed the same.
I bought one that was supposed to be 1.265, got it fitted and is reported as 1.35. The seller had this to say
"Hi. Like you asked me to I used the core temp program to find the vid of the chip. It stated 1.26 on my old board. This board was an xfx 780i. Would this make any difference? I don't know! In real temp it said its lowest was 1.25 and highest as 1.32 like you have said. But I have given you the one from core temp which seemed right being inbetween the low and high"
With VID there is no going inbetween any low or high? Do you think the seller has possibly got mixed up with the voltage as it lowers and increases based on load? I would like to think this instead of him trying to sell me a higher VID on purpose, in the hope that I do not find out.
