hi guys, hopefully one of you can help me
so i was running windows 7 and i had a perfectly stable overclock on my i7 4770k of 4.5ghz i have recently upgraded to windows 8 before i upgraded i knocked all my overclocks off so everything was stock
after insalling windows 8 i used msi live update 6 to make sure i had the latest versions of drivers and motherboard bios then went back to reapply my overclock only to find i can no longer set the CPU voltage to manual mode
my 4.5ghz overclock was perfectly stable with the CPU voltage manualy set to 1.25 and temps where decent aswell but now i can only chose auto, adaptive and override, no manual
so now when i set my 4.5ghz overclock on all 3 voltage settings it uses more voltage than it needs sometimes peeking at 1.3 and the temps are going crazy as a result
does anyone know how i can get manual voltage mode back?
my motherboard is the MSI GD65 gaming z87
thanks
thanks
