CPU Waterblock upgrade
7 Jul 2005
I currently have a Swiftech Storm cpu block on my q6600 and am looking to upgrade it to a D-Tek FuZion Universal CPU Waterblock - anyone know if i will have to remove my motherboard to fit it or will i be able to use the mounting screws from the Storm ?
Dont really want the hassle of removing everything again.
Thanks
Dazza
Well the bolts will be in the same place, it's just a case of whether the Storms bolts are thin enough to go through the Fuzions mounting holes (they probably are).
