Hey,
Want to start OC'ing my 955BE as i've my pc built since September and havn't done any Overclocking with it. So i bought a 'second hand' radiator, pump and cpu block.
XSPC RX 120 Radiator
XSPC X2O 450 Pumpstation
HEATKILLER® CPU Rev3.0 754/939/AM2/AM3 LT Water Block [10195]
Also bought Nanoxia Extreme Stark 1000ml water and Cool Laboratory Liquid Metal Pro Cooling Paste thinking i could get going.
And then the problems started. Simply the radiator won't fit into my case (CM Storm Scout). At the back the rad blocks room for the 8pin and its just to big to mount as srews don't line up, at the top it gets in way of the ram. Can't put it anywhere near dvd drives so...
I guess the only other alternitives is to buy another RAD which fill it.
Any suggestions
Thanks,
Any suggestions
?Thanks,
Edit: They wouldn't work as there 1/4 outer thread =/
