CPU-z problem (I think)
16 Apr 2006
Basingstoke
hi I have an AMD Athlon 4200 on AM2, but CPU's only lets me see one core not both of them, is that correct of is there a problem with CPU-Z?
thanks Phil
if you go into device manager and look under CPU's, do you see the two cores listed in there? If you do then it's probably to do with CPU-Z.
CPU-Z 1.37 does not show dual core CPUs as dual CPUs. If you look at the bottom of the CPU window (the first one it opens on) it will show a greyed out drop-down menu, next to that it will say Cores: 2 Threads: 2.
There is no problem with CPU-Z.
