Crack in cpu Cooler
20 Oct 2011
Would you be worried about what appears to be cracks in my cpu cooler
https://~ibb.co~/QNhhzP0 https://i.~ibb.co~/HzRR1tZ/IMG-0287.jpg
https://i.~ibb.co~/xjSrGKb/IMG-0286.jpg
I would yeah
Had micro cracks in acrylic before
They leaked eventually
But then I have 3 or 4 spares
In my cupboard
And quick disconnects
So swapping cpu blocks wouldn't
Require draining down to do it
I only done it finger tight and its been ok for last 2 years :)
I do hate perspex and it does crack for little or no reason at all, especially when drilled/machined (or when you use solvent glue, or look at it sideways...). A bit of heat on cut edges will help seal any micro cracks but watch it doesn't warp/bend :)
