crashday direct x problem?
12 Feb 2004
Chesterfield
Have had this working but last night refused to load quoting something along the lines of unable to initiate direct x subsystem, your system config is invalid. Everything else is working fine, have tried uninstalling and reinstalling graphics and sound drivers, have uninstalled and reinstalled the game - twice and run dxdiag which says everything is ok. Anyone any ideas?
Sounds like a very strange problem to me????
I think your best solution is to get rid of your pants graphics card and start over with something decent !!!!
heeheehee....
StevieP
At least I can put the side on my pc without it sounding like a industrial vacuum cleaner....... :p
OUCH !!!! :(
Fair point......and if you must insult my machine, get it right...its more like an F14 taking off!!!
Oh my kingdom for a Freezer 64!!!
StevieP
edit..
Get your sig updated!! (1gb indeed!)
isnt there a launcher you can edit graphics resolutions and sound etc before launching the game? if so try lowering settings.
I'll check but seem to think that all graphics/sound options are set in the in-game menu.
