Crashing Issues with SSD, fine with Mechanical Hard Drive ..Help!
11 Dec 2003
Sol
Hi all,
Very very strange problem going on, I've been speaking with @Bailey on support and we can't draw any conclusion on this, but I was wondering if anyone might have ANY ideas on what I could do!
I've built a new PC (Spec at the bottom of the post)
Installed Windows 10 as you do, everything went fine, went to installed Windows Creative Update, locked up on downloading, restarted, locked up again on downloading, went to download Nvidia Drivers, locks up during installation, same issue with any software installation at all.
I ran memtest86+ to ensure RAM was fine, left it on for a weekend, 50 passes, no errors, RAM is clear as far as we are aware.
I decided to grab a mechanical hard drive I had lying around, Windows installed, Creative Update went fine, Nvidia drivers installed and working, ran Prim95 for 2 days solid, no issues, no crashes, no problems.
Ok, faulty SSD? Grabbed another SSD and ran into the same problems with this one (Sandisk) as the original (Hynix).
To say I'm a bit confused right now is a massive understatement! Anyone got any ideas?
Hardware spec:
Gigabyte GA-AB350M-Gaming 3 AMD B350 (Socket AM4) DDR4 Micro ATX Motherboard
MB-559-GI
AMD Ryzen 3 Quad Core 1200 3.40GHz (Socket AM4) Processor - Retail
CP-3A6-AM
Corsair CX-M Series 450W 80 Plus Bronze Semi Modular Power Supply (CP-9020101-UK)
CA-219-CS
Hynix SL308 120GB 2.5" SATA 6Gb/s Solid State Hard Drive (HFS120G32TND-N1A0A)
HD-014-SH
Team Group Dark Pro 8GB (2x4GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Black/Red (TDPRD48G3200
MY-073-TG
Cougar MG100 Micro-ATX Gaming Case - Black
CA-010-CU
WD Blue 1TB 7200rpm SATA 6Gb/s 64MB Cache HDD - OEM (WD10EZEX)
HD-366-WD
Asus 24x DVD±RW DRW-24D5MT SATA ReWriter - Black (OEM)
CD-069-AS
KFA2 GeForce GTX 1050 OC 2048MB GDDR5 PCI-Express Graphics Card
GX-09A-KF
Sorry, I forgot to mention, I did test with some other RAM, 15 passes on MEMTEST 86+
i think and hope I might have cracked it by disabling the ASATA ports in the bios, no idea why that would make a difference, but I did another full rebuild last night, things SEEM to be better, but will have to stress test it tonight.
@JasonM Yes, AHCI is set as the other option was RAID which I didn't think I would want to be using?
@Danny75 Sorry, with the mechanical hard drive I installed windows, creative update, and then ran prime 95 for 24 hours, not a fault or lockup in sight.
Yep, I've set it to AHCI now, as said last night was a lot smoother after the rebuild, everything installed fine, updates on, 3d mark ran with no issues, just hoping I've broken the back of it!
Had it on for about 9 hours last night, 3dmark all fine, stability fine..left it on for a bit, came back, green & purple screen, all was fine but with a green/purple "high contrastish" look to it..
Whatever next?
I've read up on it a bit and supposedly a graphics driver issue, but I've had it on for 36 hours since, random 3d marks at intervals with and without restarts, even let my 10 month old daughter have a look to see if she can diagnose the issue, but right now it "seems" to be working fine....stay tuned for updates & fails!
