- 27 Jun 2013
Id assume so. Since it should be given to each card sold.
I would expect so too, so I've just placed my order for them
Had both, currently have a 7950.This or a 7950?
This or a 7950?
£259 last week for the 680 and now this, very impressed. Birthday on Saturday, I believe it is time to treat myself to a 670.Hi there
This deal is absolutely bonkers, MSI found a stash of stock in their warehouse and we've taken it all as the price we've got is superb allowing us to go sub £200, YES I REPEAT, sub £200 for a GTX 670:-
MSI GeForce GTX 670 OC Twin Frozr Power Edition 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
Transform your gaming experience with the GeForce GTX670 Power Edition graphics card from MSI. Featuring the award-winning Twin Frozr thermal solution, innovative Military Class III component design, enhanced PWM configuration, and MSI's proprietary Afterburner overclocking suite, own the best graphics hardware with the GeForce GTX670 Power Edition from MSI.
The GTX670 Power Edition features the industry-leading Twin Frozr IV thermal design. With 8mm SuperPipes soldered to an all-copper, nickle-plated base, twin 80mm Propeller Blade fans, and a high density heat fin stack, the GTX670 Power Edition is up to 16C cooler than a competing design.
It also features Dust Removal Technology, which spins the fans in full reverse for 30 seconds at system start to minimize dust buildup and ensure optimal thermal performance. The GTX670 Power Edition also features a full-length heatsink that cover the front of the PCB, cooling and protecting critical components on the graphics card while preventing PCB flex.
The GTX670 Power Edition features a robust 6+1 phase PWM design that delivers 25% more current to the GPU versus the reference design for maximum performance and stability. This enhanced allows for better GPU Boost performance under load, and provides maximum power delivery and stability for gaming and overclocking.
MSI's Military Class III components meet a more stringent testing standard than industry-wide electronic components.
Utilizing the US DoD MIL-STD-810G testing protocol, Military Class III components are rated to run under the most strenuous conditions to meet the highest levels of performance.
These components include: Hi-C CAP -- Low profile tantalum core capacitors, more than 10 times the lifespan of traditional capacitors with 15 times less power leakage Solid State Choke (SSC) -- Pure iron core choke with high working current, designed for overclocking All-Solid CAP -- Nickle-plated cover for longer endurance, up to 10 years lifespan under full electrical loads
Features:-
- GeForce GTX670 GPU
- 1344 CUDA Cores, 1019MHz Base Clock, 1097MHz Boost Clock
- 256-bit 2GB GDDR5 RAM at 6008MHz
- Innovative GPU Boost, NVIDIA PhysX, NVIDIA 3D Surround technology
- 3-way SLI, DirectX 11.1, PCI Express 3.0>/li>
- Twin Frozr IV Thermal Solution with Dust Removal Technology
- Enhanced PWM Design for increased GPU Boost headroom
- Full overclocking and monitoring via MSI Afterburner software suite
- Military Class III component design for maximum performance and power efficiency
Specifications:-
- Core Clock: 1019MHz (GK104)
- Core Boost Clock: 1079MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1344
- Shader Clock: 1930MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 2x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£259.99] Inc. VAT
Only £199.99 inc VAT - PRE-ORDER ONLY PRICE!!!
ORDER NOW
This pricing is mental at anywhere between £50-£100 cheaper than our competitors and this is also the lowest price in the UK by miles for a GTX 670. But this is no regular GTX 670 this is a Power Edition which means it uses custom PCB with better power regulation, uprated more powerful yet quieter cooling allowing its performance to close onto GTX 680. Yet all this for sub £200, our stock is limited to 500 units which at this price we believe will sell out crazy quick.
Its a bargain, its end of month, get your wallets out, spend your monies or spank the credit card.![]()
ALSO INCLUDES FREE SPLINTER CELL BLACKLIST PC GAME WORTH £29.99
I know the 760 will overclock to match or better the 670, but these overclock as well so for the same money even though it sounds like an older card, they are all still based on the same gpu anyway.£259 last week for the 680 and now this, very impressed. Birthday on Saturday, I believe it is time to treat myself to a 670.
Would this be a good replacement for an MSI 560ti?
