**CRAZY SSD DEALS - 60GB @ £43.99 & 120GB @ £69.95!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
This is a truly storming deal and there is now ZERO excuse to not buy an SSD for your laptop or PC as the performance improvement over a 7200/10,000rpm HDD is huge:-
Sandisk Ultra SSD 60GB 2.5" SATA-2 Solid State Hard Drive - (SDSSDH-060G-G25) @ £43.99 inc VAT
Upgrade your laptop to high-performance and extend its battery life with the reliable SanDisk Ultra® SSD. You’ll enjoy faster boot-ups and shutdown in up to half the time compared to a 7200 RPM hard drive§. The SanDisk Ultra SSD is backed by rigorous shock and vibration testing and a 3-year limited warranty†. The SanDisk SSD features no moving parts, quiet operation, and low power consumption as compared to a 7200 RPM hard drive.
- SandForce SF-1200 Controller
- Upto 280MB/sec Read performance
- Upto 270MB/sec Write performance
- SATA-II (3Gb/s) (Compatible with all SATA versions)
- Operating temperature: 0c to 60c
- Power Active: 0.43W
- Shock Resistant: 1500G @ 0.5 msec
- Vibration: 2.17gRMS, 5-700Hz
- Delivers reliability, durability, and performance for your laptop or desktop
- Faster system boot up and shutdown .the rugged SanDisk Ultra SSD can boot up or shut down your system up to twice as fast as compared to a 7200 RPM HDD˜
- Speedy read and write performance.up to 280 MB/secö read and up to 270 MB/secö write performance Designed for high durability.engineered to withstand shocks and vibration
- Long-term endurance - the 60 GB SanDisk Ultra SSD can withstand at least 40 terabytes* of data written to it over lifetimeĢ, while the 120 GB and 240 GB drives can withstand at least 80 terabytes and 120 terabytes of data written, respectively
- Lower power consumption - as compared to a standard 7200 RPM Hard Disk Drive
- Noise reduction - the SanDisk Ultra SSD provides quiet drive operation
- 3y Warranty
Was [£59.99] Inc. VAT
Only £43.99 inc VAT.
ORDER NOW
Sandisk Ultra SSD 120GB 2.5" SATA-2 Solid State Hard Drive - (SDSSDH-120G-G25) @ £69.95 inc VAT
- 3y Warranty
Was [£94.99] Inc. VAT
Only £69.95 inc VAT.
ORDER NOW
A truly immense price for SandForce based SSD drives. :D
If you're going to order this, don't go for the 60gb guys.. the 120gb is double the space for less than 1.5x the price :)
Tempted to buy the 120gb for using photshop/illustrator/indesign/premierepro/after effects....
hmm
60's fine for me, and the £40 price point is perfect. It's only going to be for a boot drive. But yes, the 120 is a good price to be sure.
