Crc Error Counts
19 Oct 2002
Woolyback Country
How serious are these?
I have 3x4tb drives in my htpc all showing MANY errors,no other errors just crc errors (may be caused by a faulty cable) it also says
Just swap cable?or are the drives fubar?
Definitely something you want to look into - the most likely cause is some kind of interface fault i.e. cable.
If you are getting a lot of errors then its likely over time there is potential for data corruption and can be a symptom of something starting to fail - it would be a bit strange for multiple drives to all start showing the same problem at the same time if it was a failing drive (though I've noticed before they can start to stack up on other drives for some reason if you are copying data a lot between drives with one failing - maybe they are having to correct data coming from that drive :S).
Will swap all the cables on the 3 drives,make a note of how many errors and see how it goes it think
Not critical data but would be a pain to reload
All other sections report ok/fine it is just the crc error tab thats iffy
EDIT
Just ran WD diag tools on the 3 iffy drives.ALL show as ok ,no errors on crc or anywhere else
Just doing a complete block by block scan but thats going to take a hile.Hopefully it passes ok
Looks like Hdtune is giving false reports then?
Both my SSDs got 7000+ crc errors accumulated over a couple of days of crashes due to cheap cables. Replaced the cables with thicker ones and have had a single crc error in the last 2 years and no other issues at all.
