I typed this thread in a bit of a hurry. The bed is a square wooden frame, with a thin piece of plywood on top. the plywood has a fabric cover sewn into the plywood.
this plywood cover flexes when weight is put on, especially on slave nights....
I don't think WD40 will work on wood, but the sock idea is a pretty good solution. It may stop the frame and board rubbing together.
