Creating a Bootable USB Key... With a Difference?
Caporegime
18 Oct 2002
Lake District
Is it possible for me to create a bootable USB key which allows me to select what I would like to boot into? I'd like to have a memory stick I can boot off and run memtest86, Acronis disc image or Windows 7 setup.
It's that simple?
Edit: Just figured out that you can edit Acronis boot menu to include whatever you want!
You need a 'grub' menu
I used a tool on msfn for builing XP usb sticks, with that tool, I added a Vista setup, and can manually add most .iso files to it
I'd just look for a guide for 'bootable grub builder' or somthing like that
