Thinking of creating one to store an image of my OS partition so that if XP ever messes up I can just restore the image.
What I'd like to do is create it and hide it, a la restore partitions you get on new laptops. But how would I go about that? (the drive is not paritioned at all right now) Guess I just use some drive manager software to create the partitions, then something like Ghost in DOS mode to image the OS onto it?
Problem is, I'm not sure:
a) Should it be a primary partition or logical drive in an extended partition?
b) I presume if it's primary, it should not be set to "Active" to stop it interfering with the main OS partition?
c) If I reformat the main OS partition then Ghost from the image back to it, would I need to then do anything else to be able to get it to boot XP?
Thanks.
Thanks.
