Creating matted Messy hair
8 Mar 2005
Cardiff
At the moment I have naturally straight longish hair. As the emo trend of long, straight, black hair seems to be overtaking at the moment, I've decided to mess my hair up a bit and avoid claims that I use straighteners (which I don't).
Currently I'm using Schwarzkopf mess up gum and I used to use that surf wax stuff a while back however I find my hair never stays how I want it. Its ok for about 30 mins then it just goes flat again, even if I get my more "girly" mates to do it for me.
Anyone know any way of naturally allowing my hair to become messy and matted without resorting to excessive backcoaming? Eg special treatment or products.
Thanks in advance
Just go into a barbers and ask for a "No.1 All over" they will know exactly what you want.
on a serious note and an easy one, grab a towel and rub it round in circle on your head fairly hard for a while, its quick and will mat the hair up at the base rather quickly and isnt to much trouble to get out.
did it once after i got rid of my dreads the first time for a laugh
You might need a new cut (nothing drastic) if your hair doesnt behave the right way. Probably needs thinning out. :)
Brill idea, thanks mate, works a treat with a bit of wax. My hair just isn't long enough for dredds atm and I don't want have to start pulling out knots before I have to.
Think of long emo length (fringe to nose), that should be about it.
Had long hair for years and all the "kids" are doing it now.
I did this with my hair, I didn't brush it for about 6 months (at a guess), in the end, I had to use a hairtie to keep it back, otherwise I had two big lumps like Princess Leia hair - I recently managed to get all of the knots and matt out, fairly painful and took me sodding ages to remove, now I like it how it is, straightish and smooth. :)
the shorter your hair is, the easier it is to mess up and style. so... cut your hair or be prepared to use a lot of product to style it
first time i had dreads i had them for 6 weeks (summer hols) and it took three people, one a hairdressers, to get them out and it hurt
For the messed up look you need someone to 'chip' into your hair so it is all very slightly different lengths.If it is currently all the same length then you will not get the effect you are after.
As already mentioned, American Crew Fibre is the best product if you want it to look natural. Take a slightly larger than a pea sized amount, rub your hands together to warm it up and coat your hands in the stuff. Run your hands through your hair et voila!
Fudge do some good stuff too that will give you a more wet look, can't remember the name of it for the life of me though.
I am lucky that mny hair is curly as sin.
so, I wash it, let it dry on its own. then it gets all messy looking
not great lighting, and you need to grow it for about 14months :)
tis a piccy from the france tour. rockpics from france
Sounds like me.
And if you just cut a tiny bit off it sproings right up making it look like you've had loads off!
