Creative 7.1 audio cable for X-Fi Xtreme Music
20 Mar 2006
Hey,
I have an X-Fi Xtreme Music, and I want to use 7.1 speakers, but atm can only use 5.1 because there are only 3 analog outputs, the side speakers are split/shared over two ports, and apparently the only way to connect it up is with a Creative 7.1 4:3 audio cable which I can't find anywhere...I contacted them by email and they said to call a number, but I was wondering if anyone else knows of a solution to this?
You need 4 of these as well then:
My 7.1 speakers work fine with the xfi :confused: even though the side speakers are shared they still work separately (I think).
MeatLoaf said:
^^ Correct, you only need 3 ouptputs :)
3 outputs on the card, but I'm pretty sure you need a special cable to split two of the outputs in to 3 channels each.
If you're just running 3 normal miniplug outputs to a receiver/decoder/whatever all you're going to end up with is 5.1 upmixed to 7.1
With the cable that gives you the extra 2 channels you'll actually get 2 more 'real' channels...not that I've seen many things that can properly use 7.1 anyway.
It is 3 outputs on the card, but the cable changes 2 of the outputs from stereo to 3 channels, so 2 + 3 + 3 instead of 2 + 2 + 2.
If you have some Creative 7.1 speakers I believe you should already have the required cable.
How would that help with that cable? Not disagreeing that it would, just don't follow...
I currently run the front analog output into one of those, which i turn runs into a hi-fi system. That's fine.
Center/sub analog ---> 2.1 Speakers
Rear analog ---> 2.0 speakers
Leaving no outputs left for my 2.0 side speakers....I tried splitting the two analogs that the side ones use, but that just didn't work.
I actually have that cable you mention, but not sure how to connect it to achieve 7.1...I presume two of the RCAs can go directly into my hi-fi, but how would I connect the two l/r RCAs via the 3.5mm stereo adaptor for the others?
I foresee needing 3.5 stereo male/female converters....I presume the two green ones will go into my hi-fi, then if I convert two of the blue and two of the red into 3.5mm for my center/sub and rear speakers, then that will leave me with a red and a blue to connect together for my side speakers? How do I know which ones to leave, or does it matter?
If it's a hi-fi setup as opposed to normal 'PC' speakers then all 8 phonos should go in to the back of your receiver/amp and then the speakers obviously output from there as well.
Have you got any photos/pictures/diagrams of your current setup, specifically the input ports on the back of your amp/receiver?
Only my front speakers are the hi-fi setup, the others are all normal 'pc' speakers...
One set of hi-fi amp + 2 speakers (front)
One set of PC 2.1 speakers (1 stereo 3.5mm jack) (center/sub)
Two sets of PC 2.0 speakers (stereo 3.5mm) (rear and side)
I hope my effort at a diagram isn't too bad:
(The cable comes in as 3 wires at the bottom then splits out)
The cable I put a link up to that you already have should have labels as to which channel goes where, I think you just need 3 of those other adapters I showed, and also a 3.5mm gender changer adapater for each so you can plug the PC speakers in to it.
I don't think you'll be able to get a proper LFE channel on that though so I would recommend only plugging the centre channel in to the 2.1 set. Should be plenty of bass with the hi-fi speakers anyway.
Took me a min or two to work out the diagram, but I understand...yeah that's pretty much what I want...now the question is, where did I put that damn cable..I might have left it at uni...
Also, gna need 3x stereo RCA -> 3.5mm stereo adaptors and 2x 3.5mm stereo male/female (already have one)...******s here I come...
Cheers
