creative x-fi extreme music
7 Mar 2005
EIRE[for munster rubgy]
got the above sound card to replace my audigy 2
its running on abit av8 3 eye mobo
did unstall of audigy software and installed new ,installed new card ,booted up system,but sytem boots up and just hangs there,no postin or going into windows,turn off pc ,move to different pci slot,same thing,take out xtreme music and boot system ,system boots to windows,so turn off again and start up ,and doent post or go to windows
av8 has a code display saying c1 which means detect memory
what the hell
any ideas
Firegod said:
Have you tried perhaps re-setting the CMOS, then putting the card in, and booting up again.
havent yet
after sevral trys, when i took out the card,the cmoswas changed according to system
what do i change
KELTICKNIGHT said:
havent yet
what do i change
There should be a jumper on the mobo which you move, leave for 30 seconds, then move back. When you boot up now all the settings are wiped and the board is reset. It should say in the manual where it's located.
tryed it and still the same
i know there was or still is probs with nivida chipset on certain mobos,is there also issues with via
Are you using the drivers that came with the card or have you downloaded the latest ones from creative. I would remove the ones you have and down load the latest ones. I had problems with my nForce chipset motherboard for several days and the new down load fixed it. Worth a try
moved jumpers,reset to defaults and disabled onboard sound,still the same
after several trys,cmos is reset without me doing it,somehow the x-fi is
Is the BIOS up-to-date and/or is there perhaps a 3rd party BIOS available to try on the mobo?
I noticed you said originally it hangs on C1 - Detect Memory. Have you tried perhaps with one DIMM in the board, or have the memory in another slot?
bios od av8 is up toDATE
as far as c1 =dectct memory,this only shows when the xtreme music is in pci slot ,if i remove the card,this error doent show at all,and even when i put in another audigy,works well
so this eror only there when xtreme music in in pc,there must be a problem wirh the card
It does sound like it unfortunately, you've tried pretty much everything else. Shame you don't have another PC in which you could try it out.
