Critise Build for Friend Please
I hope 2nd part of this sentence has nothing to do with following words
Torrent
Pirate Bay
Windows 7/8 Activator
No, I work as a Network Manager and nearly all of our software is licensed for use for the business and also for giving to staff for home.
Dont worry this is all "friendly banter" as Honosourri would say or whatever his name is :)
I choose a different Air Cooler, you think that will clear the slots fine?
Look at the pictures in the review, it sure will. One of the heatsink stacks is thinner than the other.
This means if you fill all four RAM slots with that colourfull memory then you will see all of it.
Just a question he also needs to buy
http://www.overclockers.co.uk/showproduct.php?prodid=cb-089-ok&groupid=1929&catid=1757&subcat=
because the card only has mdp or dvi-d for a decent picture. i know dvi-d to mdp works good through an adapter but i have no used a mdp -> dp adapter, will it have any adverse effects on the picture quality?
http://uk.msi.com/product/vga/r7970-2pmd3gd5-oc.html
Video Output Function
Dual-link DVI x 1
Mini DisplayPort x 2
HDMI x 1
http://www.samsung.com/hk_en/consum...A850DS/XK-spec?subsubtype=sa650-and-sa850-led
Signal Input
Video Signal: Dual Link DVI, DP
Connector: Dual Link DVI x 2, DP
Hopefully the screen may come with a dual link cable?
