Hi, I recently upgraded my motherboard and memory to accommodate a second Radeon HD 4890 into my gaming rig.
I bought a 600watt Alpine PSU since it seemed the best value but it only has 2x 6pin PCI-e power connectors on. I thought buying 2x 4pin Molex to 6pin PCI-E adapters would be sufficient but when I hooked it all up yesterday it sounded like it was struggling before it decided to power itself off.
Since my graphics cards require 4x 6pin PCI-E's between them, will I HAVE to buy a PSU with those connectors built in or do I have an alternative?
I would have bought one in the first place but I'm on a pretty tight budget and the only PSU's I could find seemed excessive
Thanks
Thanks
