Howdo,
I'm going to be going crossfire at some point with my current 5830, but unsure about the power cabling. I have a 650w Corsair PSU, which will be fine for it seeing as the Sapphires pull under 500w load in crossfire.
Thing is, the PSU only has two 6+2 pin power connectors, I will need 4 6 pin power connectors.
If I get two of these, I will need to use up 4 molex plugs to add the two additional 6 pin connectors. I will then be using these to go with it and make it look pretty.
Could I get away with getting some adapters that just use 1 molex, and having the cards powered by 1 of the PSUs 6 pin connectors, and 1 single molex to 6 pin connector, with the braided extenders on each?
Cheers!
Cheers!
