Crossfire Help
17 Jan 2012
Can any 1 help we this 1 I Have got 2 asus HD 7970 DirectCU II in crossfire.When i enable Crossfire the second card is on full load and crashes sum times. i have tried at least 5 different drivers out there and all doing the same thing
both of the cards are fully working in non crossfire.
The specs are
AMD FX 8320 @4700mhz
Asus Crosshair V Formula Z AMD 990FX
corshire 850 pw
Ram 16gb G skill 1600mhz
2 samsung 840 SSD
I had a huge problem when i first crossfired,although mine crashed all the time from the moment it was enabled but both cards worked perfect with it disabled. Long story short my problem came down ULPS.
Basically i had to disable ulps through the registry its a powersaving sceme that messed with my second gpu, Although i dont think this is your problem give it a go!
Search the registry for enableULPS and change the 1 to 0
Hope it works although i dont think it will!
