As in the pics, have you really enabled manual fan control @ 20%, if so, thats exactly where your problem is !
However, if you only did that temporarily then you may want to install MSI Afterburner and create a custom fan profile.
It will be the bottom one, I don't see how the other could be the coolest.which one is the coolest physically? the bottom one or the top one in the motherboard?
a) Dust filters
b) change the H50 so air is going out, not in.
c) change the side fan to blowing in (it looks like it should blow directly on the the cards)
d) clean that sucker up.
e) can you sort the cables a bit better.
f) can you DIY a 120mm fan at the bottom of the 5 1/4 bays that will blow more air on to the cards.
Changing case will only help in part, as it is to do with your motherboads slots that will depend on the gap between cards. A better case will help a bit but not a great deal.
To be fair, your case and cooling should be fine enough to keep your cards cool, as suggested previously, ensure your H50 is pushing air out of the case and ensure your front case fans are bringing air in.
What I did with my case was move anything in my front bays to the very bottom of the case then ensured there was good airflow from the top two fans.
Hi JaffAWood, thanks for your advice!
I haven't tried them in seperately, perhaps it's something I should try.
I have some more pics for you...
The bottom card was filthy,.. full of dust ( But this wasn't the one overheating I don't believe ) - this was at 58 celc but only 11% activity.
I took the H-50 off, turned it around, and cleaned those fans and the radiator ( which was fairly dusty ).
I then took the side fan off, turned it around, and cleaned that fan.
I took the spot fan off, cleaned that, and put it back on.
I'm considering a new side fan also, I have a spare somewhere so I can have two side fans, but it's much much cleaner now inside. My top card idling is now at 38 celc rather than 46, but I did also swap the cards over ( top is now bottom ).
Speedfan is showing my CPU at 19 celc idle, I have the window open though and it's not been on long ( It's overclocked from 2.6Ghz to 3.8Ghz, so will no doubt rise ).
I played Battlefield yesterday, and turned on the crossfire status icon, which showed in the top right, so I think crossfire is enabled and working, but I will delete the drivers and reinstall anyway, to make sure.
No buzzing or whining... It's not hugely powerful though, it's a Corsair TX650, but I hope it's enough for this setup?
I just removed CCC, booted into safe mode, used driver sweeper, restarted and reinstalled from the AMD site - and took off the front panel to clean the fan whilst I was restarting.
It's now reporting 55 celc for my top card, 0 for my second card.
That's not totally idle though, it's got two monitors, one showing skype etc, the other browsing the net
