- 22 Jul 2009
Hi All,
I've recently purchased a Crucial 54 GB SSD. Unfortunately it seemed to suffer from random slow downs. It also failed to format correctly in Windows and during windows setup. It was replaced a few days ago but the new disk seems to be doing the same thing.
I've tried using my standard HDD (WD120) and it works fine. So I can only assume that the new HDD is faulty as well OR there is a fault with the Crucial range. I bought Crucial simply because I use their memory and have never had a problem.
Has anyone else bought a crucial ssd and are you experiencing these problems? Does anyone have any advice?
Kind Regards
Stuart
Kind Regards
Stuart
