I read somewhere that it is two drives in one,the first with quite a small cache of decent performance nand and then a larger one that's not so fast,any idea if that's accurate?
Essentially it is as it carries an SLC/DRAM cache infront of the main TLC storage. The cache values are:
960GB = 12GB of cache
480GB = 6GB of cache
240GB = 3GB of cache
If you move files larger than the cache size for the drive then the write speed drops off quite considerably!
