Crucial M500 SMART data help.
1 Dec 2010
North Wales
Hi i bought a M500 a couple of days ago and after getting windows installed and everything set up i ran a SMART test. the details come back as follows
-- Physical Disk Information - Disk: #2: Crucial_CT120M500SSD1 --
Hard Disk Summary
Hard Disk Number . . . . . . . . . . . . . . . . : 2
Interface . . . . . . . . . . . . . . . . . . . : S-ATA Gen3, 6 Gbps
Disk Controller . . . . . . . . . . . . . . . . : Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller (AHCI) [VEN: 8086, DEV: 1E02]
Disk Location . . . . . . . . . . . . . . . . . : Bus Number 0, Target Id 0, LUN 0
Hard Disk Model ID . . . . . . . . . . . . . . . : Crucial_CT120M500SSD1
Firmware Revision . . . . . . . . . . . . . . . : MU03
Total Size . . . . . . . . . . . . . . . . . . . : 114470 MB
Power State . . . . . . . . . . . . . . . . . . : Active
Logical Drive(s) . . . . . . . . . . . . . . . . : C: []
Current Temperature . . . . . . . . . . . . . . : 26 °C
Maximum Temperature (Ever Measured) . . . . . . : 30 °C, 28/09/2013 16:48:25
Minimum Temperature (Ever Measured) . . . . . . : 21 °C, 29/09/2013 11:38:03
Power On Time . . . . . . . . . . . . . . . . . : 1 days, 23 hours
Estimated Remaining Lifetime . . . . . . . . . . : 746 days
Health . . . . . . . . . . . . . . . . . . . . . : ############-------- 64 % (Fair)
Performance . . . . . . . . . . . . . . . . . . : #################### 100 % (Excellent)
The drive tried to examine and reallocate data sector(s) 16 times. The examined data area is perfect.
At this point, warranty replacement of the disk is not yet possible, only if the health drops further.
It is recommended to examine the log of the disk regularly. All new problems found will be logged there.
The TRIM feature of the SSD is supported and enabled for optimal performance.
It is recommended to continuously monitor the hard disk status.
ATA Information
Hard Disk Cylinders . . . . . . . . . . . . . . : 232581
Hard Disk Heads . . . . . . . . . . . . . . . . : 16
Hard Disk Sectors . . . . . . . . . . . . . . . : 63
ATA Revision . . . . . . . . . . . . . . . . . . : ATA8-ACS version 6
Transport Version . . . . . . . . . . . . . . . : SATA Rev 2.6
Total Sectors . . . . . . . . . . . . . . . . . : 29305206
Bytes Per Sector . . . . . . . . . . . . . . . . : 4096 [Advanced Format]
Multiple Sectors . . . . . . . . . . . . . . . . : 16
Error Correction Bytes . . . . . . . . . . . . . : 0
Unformatted Capacity . . . . . . . . . . . . . . : 114473 MB
Maximum PIO Mode . . . . . . . . . . . . . . . . : 4
Maximum Multiword DMA Mode . . . . . . . . . . . : 2
Maximum UDMA Mode . . . . . . . . . . . . . . . : 6 Gbps (6)
Active UDMA Mode . . . . . . . . . . . . . . . . : 6 Gbps (5)
Minimum Multiword DMA Transfer Time . . . . . . : 120 ns
Recommended Multiword DMA Transfer Time . . . . : 120 ns
Minimum PIO Transfer Time Without IORDY . . . . : 120 ns
Minimum PIO Transfer Time With IORDY . . . . . . : 120 ns
ATA Control Byte . . . . . . . . . . . . . . . . : Valid
ATA Checksum Value . . . . . . . . . . . . . . . : Valid
Acoustic Management Configuration
Acoustic Management . . . . . . . . . . . . . . : Not supported
Acoustic Management . . . . . . . . . . . . . . : Disabled
Current Acoustic Level . . . . . . . . . . . . . : Default (00h)
Recommended Acoustic Level . . . . . . . . . . . : Default (00h)
ATA Features
Read Ahead Buffer . . . . . . . . . . . . . . . : Supported, Enabled
DMA . . . . . . . . . . . . . . . . . . . . . . : Supported
Ultra DMA . . . . . . . . . . . . . . . . . . . : Supported
S.M.A.R.T. . . . . . . . . . . . . . . . . . . . : Supported
Power Management . . . . . . . . . . . . . . . . : Supported
Write Cache . . . . . . . . . . . . . . . . . . : Supported
Host Protected Area . . . . . . . . . . . . . . : Supported
Advanced Power Management . . . . . . . . . . . : Supported, Enabled
Advanced Power Management Level . . . . . . . . : Maximum performance and power consumption (254)
Extended Power Management . . . . . . . . . . . : Not supported
Power Up In Standby . . . . . . . . . . . . . . : Not supported
48-Bit LBA Addressing . . . . . . . . . . . . . : Supported
Device Configuration Overlay . . . . . . . . . . : Supported
IORDY Support . . . . . . . . . . . . . . . . . : Supported
Read/Write DMA Queue . . . . . . . . . . . . . . : Not supported
NOP Command . . . . . . . . . . . . . . . . . . : Supported
Trusted Computing . . . . . . . . . . . . . . . : Supported
64-Bit World Wide ID . . . . . . . . . . . . . . : 0A5051074209F748
Streaming . . . . . . . . . . . . . . . . . . . : Not supported
Media Card Pass Through . . . . . . . . . . . . : Not supported
General Purpose Logging . . . . . . . . . . . . : Supported
Error Logging . . . . . . . . . . . . . . . . . : Supported
CFA Feature Set . . . . . . . . . . . . . . . . : Not supported
CFast Device . . . . . . . . . . . . . . . . . . : Not supported
Long Physical Sectors (8) . . . . . . . . . . . : Supported
Long Logical Sectors . . . . . . . . . . . . . . : Not supported
Write-Read-Verify . . . . . . . . . . . . . . . : Supported, Disabled
NV Cache Feature . . . . . . . . . . . . . . . . : Not supported
NV Cache Power Mode . . . . . . . . . . . . . . : Not supported
NV Cache Size . . . . . . . . . . . . . . . . . : Not supported
Free-fall Control . . . . . . . . . . . . . . . : Not supported
Free-fall Control Sensitivity . . . . . . . . . : Not supported
Nominal Media Rotation Rate . . . . . . . . . . : Non-rotating Media (SSD)
SSD Features
Data Set Management . . . . . . . . . . . . . . : Supported
TRIM Command . . . . . . . . . . . . . . . . . . : Supported
Deterministic Read After TRIM . . . . . . . . . : Supported
Operating System TRIM Function . . . . . . . . . : Supported, Enabled
S.M.A.R.T. Details
Off-line Data Collection Status . . . . . . . . : Never Started
Self Test Execution Status . . . . . . . . . . . : Successfully Completed
Total Time To Complete Off-line Data Collection : 555 seconds
Execute Off-line Immediate . . . . . . . . . . . : Supported
Abort/restart Off-line By Host . . . . . . . . . : Not supported
Off-line Read Scanning . . . . . . . . . . . . . : Supported
Short Self-test . . . . . . . . . . . . . . . . : Supported
Extended Self-test . . . . . . . . . . . . . . . : Supported
Conveyance Self-test . . . . . . . . . . . . . . : Supported
Selective Self-Test . . . . . . . . . . . . . . : Supported
Save Data Before/After Power Saving Mode . . . . : Supported
Enable/Disable Attribute Autosave . . . . . . . : Supported
Error Logging Capability . . . . . . . . . . . . : Supported
Short Self-test Estimated Time . . . . . . . . . : 2 minutes
Extended Self-test Estimated Time . . . . . . . : 9 minutes
Conveyance Self-test Estimated Time . . . . . . : 3 minutes
Last Short Self-test Result . . . . . . . . . . : Never Started
Last Short Self-test Date . . . . . . . . . . . : Never Started
Last Extended Self-test Result . . . . . . . . . : Never Started
Last Extended Self-test Date . . . . . . . . . . : Never Started
Last Conveyance Self-test Result . . . . . . . . : Never Started
Last Conveyance Self-test Date . . . . . . . . . : Never Started
Security Mode
Security Mode . . . . . . . . . . . . . . . . . : Supported
Security Erase . . . . . . . . . . . . . . . . . : Supported
Security Erase Time . . . . . . . . . . . . . . : 2 minutes
Security Enhanced Erase Feature . . . . . . . . : Supported
Security Enhanced Erase Time . . . . . . . . . . : 2 minutes
Security Enabled . . . . . . . . . . . . . . . . : No
Security Locked . . . . . . . . . . . . . . . . : No
Security Frozen . . . . . . . . . . . . . . . . : Yes
Security Counter Expired . . . . . . . . . . . . : No
Security Level . . . . . . . . . . . . . . . . . : High
Serial ATA Features
S-ATA Compliance . . . . . . . . . . . . . . . . : Yes
S-ATA I Signaling Speed (1.5 Gps) . . . . . . . : Supported
S-ATA II Signaling Speed (3 Gps) . . . . . . . . : Supported
S-ATA Gen3 Signaling Speed (6 Gps) . . . . . . . : Supported
Receipt Of Power Management Requests From Host . : Supported
PHY Event Counters . . . . . . . . . . . . . . . : Supported
Non-Zero Buffer Offsets In DMA Setup FIS . . . . : Not supported
DMA Setup Auto-Activate Optimization . . . . . . : Supported, Disabled
Device Initiating Interface Power Management . . : Supported, Disabled
In-Order Data Delivery . . . . . . . . . . . . . : Not supported
Asynchronous Notification . . . . . . . . . . . : Supported, Disabled
Software Settings Preservation . . . . . . . . . : Supported, Enabled
Native Command Queuing (NCQ) . . . . . . . . . . : Supported
Queue Length . . . . . . . . . . . . . . . . . . : 32
Disk Information
Disk Information
Form Factor . . . . . . . . . . . . . . . . . . : 2.5"
Capacity . . . . . . . . . . . . . . . . . . . . : 120 GB (120 x 1,000,000 bytes)
SSD Controller . . . . . . . . . . . . . . . . . : Marvell 88SS9187
Disk Interface . . . . . . . . . . . . . . . . . : ?
Device Type . . . . . . . . . . . . . . . . . . : Micron 20nm MLC NAND
Width . . . . . . . . . . . . . . . . . . . . . : 69.8 mm (2.7 inch)
Depth . . . . . . . . . . . . . . . . . . . . . : 100.0 mm (3.9 inch)
Height . . . . . . . . . . . . . . . . . . . . . : 9.5 mm (0.4 inch)
S.M.A.R.T.
No. Attribute Thre.. Value Worst Data Status Flags
1 Raw Read Error Rate 0 100 100 000000000013 OK (Always passing) Self Preserving, Error-Rate, Performance, Statistica..
5 Reallocated Sectors Co.. 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical, Critical
9 Power On Time Count 0 100 100 00000000002F OK (Always passing) Self Preserving, Event Count, Statistical
12 Drive Power Cycle Count 0 100 100 00000000000D OK (Always passing) Self Preserving, Event Count, Statistical
171 Vendor-specific 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
172 Vendor-specific 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
173 Vendor-specific 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
174 Vendor-specific 0 100 100 000000000004 OK (Always passing) Self Preserving, Event Count, Statistical
180 Vendor-specific 0 0 0 0000000007C6 OK (Always passing) Self Preserving, Event Count, Statistical, Critical
183 SATA Downshift Count 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
184 End-to-End Error Count 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
187 Reported Uncorrectable.. 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
194 Disk Temperature 0 74 70 001E0015001A OK (Always passing) Self Preserving, Statistical
196 Reallocation Event Count 0 100 100 000000000010 OK (Always passing) Self Preserving, Event Count, Statistical
197 Current Pending Sector.. 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
198 Off-Line Uncorrectable.. 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count
199 Ultra ATA CRC Error Co.. 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
202 Data Address Mark Errors 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Critical
206 Flying Height 0 100 100 000000000000 OK (Always passing) Error-Rate, Performance, Statistical
210 Vendor-specific 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
246 Vendor-specific 0 100 100 000023C5B2B4 OK (Always passing) Self Preserving, Event Count, Statistical
247 Vendor-specific 0 100 100 000000757C31 OK (Always passing) Self Preserving, Event Count, Statistical
248 Vendor-specific 0 100 100 000000AA78EE OK (Always passing) Self Preserving, Event Count, Statistical
The test is saying its only 66% healthy and its attempted to move sectors 16 times? Is this a bad drive do you think? Thanks for the help.
I suspect your SMART software is interpretting the health value returned by the drive as a decimal number, when it is in fact a hexadecimal humber.
64 hex = 100 decimal.
This happens because what format the drive returns the number in is vendor specific but if the drive is a newish model and the software doesn't recognise the model it has to guess which format was used. Given that it mis-interpreted this value I would treat any other conclusions reported by the software with a pinch of salt.
Download SSDLife Pro on a three day trial and run that. It will give you a complete run down on your SMART interface. Don't bother buying it because you are entering into a subscription which will repeat every year.
