Crysis 3 locked at 30 FPS - can I unlock it?
30 Mar 2016
East Lothian
As the title says - playing Crysis 3 for the first time but the game is locked at 30 FPS. I had similar problems when playing Crysis 1 & 2 recently but was able press ALT and RETURN to bring this up to 60 FPS albeit for Crysis 2 I had play it windowed mode. Is there a fix for playing Crysis 3 above 30 FPS?
not sure how to fix it but it worked straight out for me over 60 fps. Same with Crysis 2. Do all other games do that or just the Crysis series?
Thanks for the suggestions guys - it is only the Crysis series I've had issues with. I'm playing on the Acer XR34 75hz 3440x1440 monitor but I think I've got it sorted now. I just restarted the game and all of a sudden it's fine now although the FPS does dip from 60+ down to 33 occasionally with all settings maxed but then it is a stunningly detailed game...
