Might be worth uninstalling the graphics drivers and trying the new 169.17's just released.
I have the latest drivers, well there about a week old, when were the new ones released?
If i download the latest drivers, and install them will they just overright the old ones? or do the old ones need unistalling first?
Noooo, never do it that way! Download Driver Cleaner Pro (freeware), uninstall the current drivers, restart in safe mode, use DCPro to get rid of old files, then install the new drivers.
ahhh man, thats effort!
I'll do it tomorrow lol.
thanks for you help mate![]()
just would like to know but why restart in safe mode ? is there some thing wrong with useing driverclean on normal boot?
just want to check to make sure i not doing it the wrong way lol
The only time I get any sort of crazy graphic error is when my Graphics Card has busted (happened with two 9800pro) - seemed to be from heat (the first one had melted parts on it :O) so maybe it's overheated?
If it does it in other games/carries over to the desktop then I'd say that applies to you...but if it's only after exiting Crysis...then I don't know.
I've always installed nVidia drivers straight over the older version for years, and never had any issues. I know a few others on these forums do the same without any problem.
no it starts it in cryis then keeps doing it after i exit.
are you suggesting my card is faulty?
how do you get the card temp?
