crysis settings
13 Jan 2006
Wigan
got crysis for xmas and have just installed it,
spec is in the sig and im running it on all medium on 1680 x 1050 and only geting about 25fps and when any action starts it drops to under 10.
i thinking this is alittle low for what i am using.
are there any particular nvidia drivers i should use that work better with crysis?
im on 169.25 atm, think there beta. im also using vista64.
ty for any help
edit* im also unable to run the crysis64 exe for somereason.
I get better FPS with higher settings than you on my worse (but not by much) rig. I guess it's because of Vista. I can't help you there mate
I get quite good performance on 1440x900 (highest my monitor will go) with everything on very high (bar processing as motion blur makes me ill).
E6400 @ 3Ghz
2GB DDr2 @ 840
8800GT
ive talked to a friend who has an 8800gts and rest similar to me and he is gettting 50 - 60 fps with medium/high settings on same res but he is on xp, could my crap fps be down to vista?
a little update, ive just downloaded SP1 for vista and it has made a huge difference in fps figures. im now on everything high and geting 25 - 35 fps.
im on 1680 x 1050 all medium at 45fps with a 8800gt sc and e6750 stock, 2gb ocz
with xp though, so vista could be the problem,
