cs:source graphics problem @ 8800 gts
29 Apr 2006
check these images and tell me if there is any way to fix this becuase it's very annoying and I always kill my own team lol.
I have a 8800 GTS with the latest drivers.
http://img408.imageshack.us/img408/5716/dedust200003dc.jpg
http://img408.imageshack.us/img408/7568/csassault00008om.jpg
Thanks
R3DBuLL said:
I don't have answer to your question but noticed it's running at 56fps on the pic showing. That can't be right :confused:
Running 1680*1050 on everything maxed and always getting 60 fps no matter what i do or where i stand it won't go above 60 fps
and the max_fps is on 300.
Hi there,
This is a known issue with the G80 cards, e.g. if you go to nview forums and have a browse or google 'CS:S fog' or 'source fog issue g80' you'll find more information and widespread examples of this in CS:S and HL2
It is not a driver issue, it is an issue with the source engine that is currently being addressed. I read recently that a fix is being tested (can't find link) so hopefully it'll be sorted pretty soon
You may have vertical sync on, check your nvidia control panel
DK
iGiDK said:
Hi there,
DK
not sure what i should be looking for?
thanks
When I read about this I was concerned as CSS has been my main game, however I don't seem to suffer from the problem. I've been looking for it and there is no sign of any fog. Has anyone else said they DON'T suffer from the problem or am I a 'lucky' one?
Call my daft but I cant see a problem with the screen shots.... whats wrong with good graphics and 59fps?
what res are u at? i play on 1680*1050?
do u think i should be getting more than 60 fps?
got a e6600 @ 3.0 ghz and 2 gb ddr 667 mhz memory. with the gts of course.
My spec -
AMD 4000+
BFG 8800 GTS
Corsair 3GB XMS
yadda....
1152 res, maximum everything, 8xMSAA 16xAF 150FPS guaranteed. It's so jaggyless it's crazy :)
Hmm I was playing tonight and noticed this does occur in some places. Seemed to be mainly on the dust maps, couldn't see it on the other ones. Bugger!
