CS3 or light room
teaboy5 said:
What would you get for editing photos? I used to have CS2 but want to up-grade, but i am unsure of what to buy.
Depends what you will be doing.
If you are going to be doing RAW work and not much post-processing then Lightroom will be fine.
How often are you using CS2 for photo editing?
Thought about Photoshop Elements 5?
More processing options than Lightroom, plus it'll still handle RAW files (as long as your camera is on the list!) and it has a built in photo organiser as well.
