CSS Help
8 Oct 2005
Midlands, UK
Hi,
I have a simple list with 5 items. For each item there is a seperate paragraph of text relating to to the list item. When i click on the list is it possible to have some css/javascript that displays this paragraph for each item below the list?
Thanks
Well found a bit of code on the net that does the job in IE, but nothing happens in Firefox. Any ideas?
Have put the script in the head tag:
Code:
<script language="javascript">
function ShowHide(element){
    target = document.all(element);
    target.style.display = (target.style.display=="none" ? "" : "none");
</script>
Then display a div like so:
Code:
<a href="javascript:ShowHide('SomeDivName')">Information gathering (including aims and objectives).</a>
<div id="SomeDivName" style="display:none">
      Stuff in this div to toggle
</div>
document.all is IE only. try this instead. :)
Code:
   document.getElementById(element).style.display = ((document.getElementById(element).style.display=="none") ? "" : "none");
</script>
Code:
</script>
Many thanks.
Was going crazy for a second there :)
Hi again.
Hope somecan help me out here, as I'm driving myself crazy.
I am using a list with 5 items - x1 div below each list item. When a user clicks a list item the div below it will be displayed. When the user clicks a different list item, the current div will be hidden and the new div displayed. I have used a colleagues code that they assure me works, but I simply can't get it working.
I'm using the following javascript in the script tag:
Code:
    div = new array()
    div[0] = "div1"
    div[1] = "div2"
    div[2] = "div3"
    div[3] = "div3"
    div[4] = "div5"
function ShowHide(id) {
    for (var i = 0; i < div.length; i++) {
    var layer = document.getElementById(div[i]);
    if (id != div[i]) {
    layer.style.display = "none";
    }else{
    layer.style.display = "block";
and have my list like this:
Code:
<ul class="main">
            <li class="maintext2"><a href="javascript:ShowHide('div1')">Item 1</a></li>
            <li class="maintext2"><a href="javascript:ShowHide('div2')">Item 2</a></li>
            <li class="maintext2"><a href="javascript:ShowHide('div3')">Item 3</a>.</li>
            <li class="maintext2"><a href="javascript:ShowHide('div4')">Item 4</a></li>
            <li class="maintext2"><a href="javascript:ShowHide('div5')">Item 5</a></li>
        </ul>
<div id="div1" style="display:none">
           ghfghfghfghf
        </div>
        <div id="div3" style="display:none">
            hjhjghjhjgh
        </div>
        <div id="div4" style="display:none">
            ytyrtyrtyrty
        </div>
        <div id="div5" style="display:none">
            hyutyutyutyutyuty
        </div>
Any ideas????
Thanks
replace
Code:
div = new array()
with
Code:
var div = new [B]A[/B]rray();
note it's case sensitive. also add a ; to end of each div assignment immediately below that.
Woah! Record response! Thanks
I'm so out of practice with Javascript and wasted a whole hour this afternoon looking at that :)
I used the accordian from mootools - that i personally thought looked good, but i was told that I can't use it on a commercial clients website????? Alwasy thought mootools and simil;ar was opensure. meh :(
that sucks. explain to the numpties that all major sites use javascript libraries nowdays. :)
