its set to 5.1
audigy 4 console is set to 5.1 too
i did a speaker test and the sub comes out of the centre/front instead of the sub.
My creative audio console only lets me choose between 2/4/5.1/...
I have not option to turn the subwoofer off
why do i need to switch it though, because it works in COD4 and QW demo. For some reason source games arent sending the sub channel to the sub.
The creative speaker test should always be perfectly fine, if it isn't then you can be sure the speakers aren't plugged in correctly or the channels are mixed up.i did a speaker test and the sub comes out of the centre/front instead of the sub.
well you've said this wich incdicates something is wrong:
