CSS rates?
23 Jun 2005
York
Recently my game has being getting a bit jerky and even bots have seemed to be lagging. I think it could be to do with my rates.
I have a 512k connection so could you please give me the rates that I should use? and how to input them? (i'm presuming via console?)
Thanks.
If you dont already have console:
While in game press esc to get to the menu
Click Options
Go to the Keyboard tab
Click on the button labeled Advanced
Tick the box next to "Enable Console" or whatever it is
Then press ` (Button above tab)
Type:
rate
cl_cmdrate
cl_updaterate
Post what the console says
Click Options
Type:
rate
cl_cmdrate
cl_updaterate
"cl_cmdrate" = "30"
"cl_updaterate" = "20"
PC is:
AMD 3700 San deigo, 2GB Crucial ballistix, 7800 256 GTX so there shouldn't be a problem with the pc.
Those are the default rates for 56k
You want to run them around -
cl_cmdrate 80
cl_updaterate 80
