Cuda benefits for Adobe products
19 Feb 2009
Ok, so here is the issue. I will be making a new machine soon, I7 based with planty of RAM, an SSD boot drive and either a NVidia 275 or an ATI 4890. So, I see that at least Photoshop supports Cuda but with my setup and budget for a graphics card (a Quadro FX is out of the question as I doubt my complete build will cost as much as one of those cards!) would I really see the difference in Photoshop? I also use several other bits of Adobe software - would any others benefit from a Cuda based card over a 4890 such as After Effects, Flash or encoding?
Badaboom video encoder supports full CUDA usage. It's slightly limited compared to other encoding apps but does output in H.264, which is obviously the most popular format right now. It doesn't seem to be too much faster than SSE4....... yet, and I think it's faster if you have more stream processors.
AFAIK there aren't any others right now although I read that it will be added to Nero Move It (also a bit limited). Oh, there is an plug in for Total Media Theatre that uses CUDA for upscaling SD video and is supposed to be pretty good.
I was disappointed to find that the CUDA support that was added to my favourite encoding app, TMPGEnc 4.0 XPress, is only used if you are using filters/effects which I don't find are needed very often.
I get the feeling that it will take some time before we see software developers really take advantage of CUDA. It is available free to developers though I think.
Yup Photoshop uses Open GL acceleration I think, so ATi and Nvidia cards will work.
It's hard to say what'll happen in the future with CUDA though. It all depends on how successful Mental Ray is if/when it's released with CUDA.
It uses OpenGL, not Cuda. I've got my GTX260 powering along PS CS4 just fine :) Wish it could make more use of it to be honest. Smooth zoom is about the only thing you'll actually notice in day to day use!
Cheers people, so basically at the moment it really doesn't seem to matter what I get! I suppose that makes life easier but I'm surprised there isn't more advantage as Nvidia have partnered up with Adobe.
