Hi all,
This is my current build, any advice would be much appreciated:
Power Supply Unit
Corsair Memory 600W Builder Series CX V2 ATX PSU
OPEN TO CHANGE (Budget - Would like to spend no more than £40 ideally)
Case
Antec 300 Three Hundred Case
OPEN TO CHANGE (Budget - Would like to spend no more than £30 ideally)
Motherboard
AsRock Z77 Extreme4 Motherboard (Socket 1155, Intel Z77, Up to 32GB DDR3, ATX, 2 x SATA3 6.0 Gb/s, Supports NVIDIA SLI and AMD CrossFireX, Premium Gold Caps)
OPEN TO CHANGE (Budget - Would like to spend no more than £115 ideally)
Processor
Intel Core i7 3770K 3.5GHz Socket 1155 8MB Cache Retail Boxed Processor
FIXED
RAM
Corsair Vengeance LP 16GB (2 x 8GB) DDR3-1600 Memory
OPEN TO CHANGE (Budget - Would like to spend no more than £85 ideally)
DVDR
Basic requirement - Ideally spend no more than £15
Graphics Card
None - Will be using Intel ivy bridge HD 4000 graphics for now, and upgrade to a graphics card at a later stage.
Harddrive
Seagate 1TB Barracuda SATA 6Gb/s 64MB 7200RPM Hard Drive
£64.99
OPEN TO CHANGE (Budget - Would like to spend no more than £70 ideally)
I would really appreciate your valuable advice and suggestions alternatives (where stated above). Thanks.
Power Supply Unit
Case
Motherboard
Processor
FIXED
RAM
DVDR
Graphics Card
Harddrive
£64.99
