So you just turn up the Scale and Layout percentage in 1440p to make the text bigger.![]()
I've done this for a few years now
if you want to keep your card for longer, then you can also pretty much ignore everything from Nvidia bar 3080/Ti & 3090.
I think the 3090 is more a 3k card now, as new games come out.
Evening all. In a number of threads I've seen a number of comments like "6500 is a 1080p card". What cards would people say are "correct" for what target resolutions?
Question arises because I'm probably going to have to buy a new screen(s) Shortly (new job, old will want it's screens back), and this will force me to upgrade my graphics.... and I'm trying to get an idea of price-for-resolution. Which combines graphics and screen, but I'm out the loop on graphics. Current config 2060 @1920x1200(?).
I'm just wondering - do we know when the next gen is (realistically) available?If you can go to 1440p 144HZ, it's really great experience without be crazy expensive. Got for 3060ti/70 or 6700XT at this res, plenty at this resolution.
That's... late enough that it might as well be next year for me. Drat. Fair enough. Might have to ask for Serious Advice shortlyRealistically Nvidia will launch 4090 in September amd AMD will try and beat them to market.
That's a great summary, thanks. And it does give me an idea of what I'll be spending. Didn't need that first born child anyway...60 fps target, high/ultra but no "bugged" settings (f.ex. like clouds @ ultra in AC: Odyssey which barely change the look from high but tank performance 30%), no ray tracing.
My 3070 handles RT really well at 1440P. I run a 170hz monitor.Or put the 3060Ti and 3070 in the 1080p bracket, where they would also be if you're taking raytracing into account.
I still consider 60 FPS completely playable.
DLSS quality.It must be extremely borderline unless you're meaning 60 average, I seem to feel a bit of input lag unless my lows are around 60. ? Are are you using DLSS balanced ?
DLSS quality.
RTX 3070 is quite a bit faster than the 3060 Ti at RT.
This year, there's also an AMD refresh first, but NV and AMD will be relasing new gen this year.
But afaik the rumours are that for AMD we get N33 first, which means 6900 XT(ish) performance, so an actual performance jump won't be seen from them until 2023 Q1/Q2 when the MCM N31 arrives for whatever obscene amount of money it ends up costing.
I just said there's going to be a refresh. Which there is. He's clearly also not looking at the top end of the market like N33 if it's 6900XT performance, he's playing game from years ago (not even got round to Fallout 4 yet) so an extreme GPU is pointless for him now. And you def don't need an top end card to play 1440p.
Don't forget that the top end comes out first and each further one takes a few months after that, so depending on what you want, it might be over a year/ 18months time until you get what you want.That's... late enough that it might as well be next year for me. Drat. Fair enough. Might have to ask for Serious Advice shortly![]()
I've just manged to get to Horizon Zero Dawn? (If got bumped up the list due to recommendations)
