Currently doing first ever build
About the SSD mounting onto the 600t harddrive cages, it does fit. There are 4 holes offset near one side of the cage and these line up with the ones on the bottom of your SSD. You will however, need to remove two of the mechanical hdd pins that are blocking the ssd from lining up. (they will just pull out)
Ok so its done *cough* now...
edit: nvm connector came loose with adding optical drive
Tomorrow is the new cooler, its at 50C in bios, which is as good as idle imo, but thats probably because of the issues mounting the cooler smudging the paste about.
EDIT 2: Thanks for the link for extension cable, ill order that soon, i also need power for the fan controller, all fans on the mobo atm, it seems to have female molex connector, however i didn't have a male molex with my xfx 850w xxx edition
