Custom build help - cabling and Power button
12 Apr 2013
Hello,
The following parts just arrived no competitor hinting. Thank you.
Antec vp550p 550w PSU
Gigabyte z77-Ds3h
i5-3750k
Sapphire radon HD 7870 (overclocked edition)
500gb HDD 7200 rpm
I plan to put this all in an old alien ware case I have found, but I have no idea how to hook up the power on button to the motherboard or even where I can get a power on button. Where can I get a cable to connect the button on the front of the case to the motherboard. And which one should I get.
Thank you
Do you know anyone who could rig up an PCB for the case of even get an old PCB with power/reset & audio and create a housing unit to fit on the case. Maybe to fit in a 5.25" or 3.5" bay.
That's a good idea but i don't unfortunately. Could take the headers out of another case but only connect the power button or will I have to buy a whole new case.
Could you mod the cover of a 5.25" bay (2 holes & buttons) to allow a power/reset button if you are able to salvage the header parts from an old case?
I could probably mod the bay that's a great idea, thank you. Also thanks for the link, hopefully I won't need it. Is it safe for now to just connect the two pins with some wire to turn it on.
Thanks
