I concur with the above statement. Thought I was going to read up a bit about watercooling but thread is a tad on the old side. And the OP hasn't been around since 2013, so maybe a whole new thread ?? Although it is understandable that doing that would be quiet an effort I'm guessing.This thread needs a serious overhaul, especially for hardline kits.
Thanks, I will do just that and come back if I have any questions ! Which I most likely will have if going through with water cooling !Honestly, if you want to understand the basics go to YouTube and watch some of the videos by JayzTwoCents. Does great easy to understand instructional videos on watercooling.
Hey guys. Thinking about getting into water cooling. Never tried it before. The recommendation in one of the older guides is to use soft 7/16mm tubing ? and 1/2 nickel fittings ? Is this correct.
Also if i am to use soft tubing i am guessing soft tubing compression fittings are important over the hard line fittings.
Also which coolant that is yellow or blue pre mixed can i just pour straight into a res ?
Hey thanks for that information. I have a H500M case. Just some more advice please.
Would the following be a good match ?
EK Coolstream SE 360 Rad,
EK Velocity DA-RGB Nickel + Plexi,
Quantum Kinetic TBE 300 D5 PWM D-RGB / reservoir combo - acetal
EK STC Classic 10/13mm compression fittings,
EK Duraclear Tubing clear 16/11mm,
EK Varder Evo 120ER RGB,
EK Cryofuel Solid Azure Blue 1L Premix
From memory there 2 sizes and they can also be awkward with thread size as well. What Radiator is it?Rather than make a new thread thought I would as here.
Anyone know what size screws I need to attack fans to the rad. Seem to have lost a load of them![]()
I think EK uses UNC 6-32 30mm screws.That's the problem. I don't know. I think there. Oth ek
ThanksI think EK uses UNC 6-32 30mm screws.
Thanks
EK Water Blocks 6-32 UNC Screw Set 30mm (20 pcs)
Order EK Water Blocks 6-32 UNC Screw Set 30mm (20 pcs) now online and benefit from fast delivery.www.overclockers.co.uk
If its the newer rads use these, if its the older XTX radiators then its different.
Yeah don't force because you'll be retapping the thread as you go. It should just wind in really easily until it gets tight. Don't over tighten either.One of them is a rx360 I think. But not 100% on the other.
I'll just have to get them and not force them if they are wrong
Note that 6-32 is standard case screws like a PCIe slot cover screw or 3.5" HDD mounting screw.
M3 is a 2.5" drive or motherboard screw but most radiators don't use M3, they use M4 or 6-32.
You can test the above and if it's not M3 or 6-32 you'll need to source M4 which are usually not used anywhere else in PCs.
Yes I think 30mm and 35mm are standard (depending on if going through fans and case, or just fans). 5mm sounds right but double check the screws aren't going to puncture any radiator tubes when tightened. If the rads have a protective plate behind the screw hole that's ideal.So any M4 30mm screws should be good?
Then to mount it to the case 5mm or are they a little longer ?
