Custom Loop Parts
The other ax rads are full price, imo not worth it. Better to fill up on cheaper good radiators than to spend double on ones which only perform a degree or two better.
Do you know how much space the case has for radiators?
Everywhere i search seems to give a different answer and the NZXT website only says a dual radiator but surely not with a case of this size.
I recommend saving cash ad grabbing the EK PE radiators over the black AX ones, as they are practically the same but half the price.
Some more searching found this!
http://forums.overclockers.co.uk/showthread.php?t=18290835
So if you set it up like in the above link, with the bottom drive way removed, you can fit a 360 and a 240. I think you need an adapter which comes with the case though.
Why have you listed monsoon acrylic tubing, do you want to go acrylic instead of rubber tubing?
YOUR BASKET
1 x EK Water Blocks EK-CoolStream PE 360 (Triple) £49.99
1 x EK Water Blocks EK-Supremacy Clean CSQ - Acetal £49.99
1 x XSPC Photon 270 Tube Reservoir £46.99
1 x EK Water Blocks EK-DCP 4.0 PWM (12V DC PWM Pump) £39.95
1 x EK Water Blocks EK-CoolStream PE 240 (Dual) £39.95
2 x Primochill Primoflex Advanced Tubing 13/10 - Clear £5.99 (£11.98)
12 x EK Water Blocks EK-CSQ Fitting 10/13mm G1/4 - Black £2.99 (£35.88)
Total : £284.30 (includes shipping : £8.00).
http://www.coolingconfigurator.com/upload/pictures/EK-FC780-GTX-WF3_NA_front_800.jpg
Ahhh, could be that you have only a dual rad mount at the bottom and at the top you have two 200mm mounts. I checked the radiator measurements with phobya radiators and unfortunately the 200mm or 400mm wont fit the case.
Dissappointing considering the sheer size of the thing. I saw a 400mm radiator mod though, if you are willing to cut the case up.
Looks to be the same size as this case: http://www.frozencpu.com/products/1..._Loop_Custom_Liquid_Cooled_Edition.html#blank
"Push the envelope and utilize liquid cooling systems that feature a push-pull configuration with top 280/360mm and bottom 240/280mm radiators up to 60mm thickness for unmatched performance."
In fact if I took out the top 200mm fan I'd imagine fitting a rad up there wouldn't be a problem :/
Sent OCUK a Webnote asking for the largest size I can fit in the case.
According to them the largest it can hold is a double.
After looking at a video on youtube (https://www.youtube.com/watch?v=-zTmQLrqNyU), it looks like I may be able to seat a larger radiator on the top inside part of the case where the top fan filter is at the moment.
Any ideas?
Thanks!
EDIT: I've only just seen your question about Acrylic Tubing.
I chose that because I wanted to go with blue tubing and non-acrylic was out of stock, but I've just read that acrylic is also more difficult to set up.
Also found this which explains rad support better than most of the other links: http://www.watercoolinguk.co.uk/p/NZXT-Phantom-Black-Full-Tower-Case_46338.html
Cheers
