- 25 May 2009
- Derbyshire
Hi guys
quick question for WC ppl out there. I'm about to have my zalman case roof panel cut to mount my corsair h50 up there. I thought it might be a good idea to future proof and have the hole cut for a 240mm rad... If the h50 doesn't cut it ( looks / application yes - cooling - maybe).
I've seen some templates of competitors sites, scan around and have a look. It's the 15mm spacing that gets me. Question is do the rads have mounting holes for 120mm fans to attach to them like the h50. If so can you mount through the case and fan and onto the rad?
Plan was to make a cut out based on 2 120 fans side by side with appropriate screw holes. The templetes I've found seem to suggest this is ok but they don't have measurements on. I won't be using the templates themselves - will have a custom oval cut out to match the intake on the front of my case me thinks.
hope this makes sense! It does to me.
ta
craig
ta
craig
Will prob just put it together without the grill for now, esy enough disassembly, as I want to use the thing.
