- 31 Jan 2018
I gather thicker rads will make it harder for fans to push/pull air through too. I'm thinking of getting these fans, what do you think?
Thanks but my parts are already on the way
Here's my list, i'd love to know what you guys think.
Water Block = XSPC Raystorm Neo TR4
Radiator = EK-CoolStream CE 560 (Quad)
Fans = Corsair CO-9050044-WW ML Series ML140
Pump and Reservoir = Thermaltake CL-W082-PL00BL-A Pacific PR22-D5 Reservoir/Pump Combo (this is a bit of risk but it's fits the mounts in my case, fingers crossed)
Tubing = Primochill LRT Advanced Clear 13mm ID 19mm OD (1/2" ID 3/4" OD)
Fittings = PrimoChill 1/2in. x 3/4in. FlexSX Series Compression Fitting - Sky White X10
Decent list of parts. I assume you went for the EK CE radiator because the XE doesn't come in a 560? Not used Corsair fans much but they're the static pressure version so should be decent. Not a fan of Thermaltake due to previous experiences but they do "clone" well. The D5 is a solid pump. Probably a good thing you went with the Primochill fittings to go with the matching tubes. Primochill manufacture to imperial specifications so can be a bit tight (nothing dipping in hot water won't fix) on metric manufactured fittings.
