Fixed up some lacquer peel around my front mud flaps today. Went pretty well and I'm pleased with how its turned out but I've got a touch of overspray which makes the surrounding paint look a little rough.
On the can it says wait 2 weeks then use a cutting compound.
What would you recommend to use? The safest one that will do the job would be good
I've got some 3M Perfect-It III fine but I'm guessing thats not going to be up to the job?
Thanks
Thanks
