Hello chaps, just wanted to get some advice on cutting case windows with rounded corners. The tools I have available are a dremel, jigsaw and have a holesaw coming soon (114mm). From practising on scrap I have found that it's nigh impossible to make the curve look good with a manual cut.
I thought I would try using the holesaw in each corner, would that work well or is there a better way?
